12v switched power in trunk?
Unfortunately the amps black wire(s) is constant hot. One of the wires must be switched to turn the amp on. I intend mold a fiberglass duct system for both intake and exhaust. The exhaust will vent out the rubber flapper valve. I just need to find 12v switched. I measured the air temp behind the lining and it was 80 degrees above trunk air temp after using the radio. Regardless of how "hot" the trunk air is it is significantly cooler than the amp area. Circulating the hot trunk air through the amp area would a huge improvement. The amp is well insulated in it's factory location with inadequate cooling fans, which is incredibly bad for electronics. I've even found upgraded fans for the amp itself. I have a pretty strong working knowledge of Bernoulli's principals and I'm sure I can get the amp temp down. I just need 12v.
Thanks for looking fwhomeboy. Unfortunately no 12v source was revealed in that thread.
Once I get this done there will be a DIY thread.
fillerf
07-11-18 04:54 AM
