Things I did to my Ls460 today
#136
Updated my 07 LS wheels from the stock 18" to these 19" LS wheel in black chrome.
Also car has new radiator, water pump, belt tensioner, serpentine belt, control arms and battery. Up next are the spark plugs, seals for both plugs and fuel pumps,valve cover gaskets and rear diff oil. Only a minor leak from right side of valve cover but since it's all coming off why not. The car currently has 175k. Oh and lastly I will be taking it in for the sticky interior soon!
ALK (05-27-20)
#138
Completed my spark plugs and all coils. Replaced both inner tie rods. All and all it has mad a difference. Dealer wanted of course $500 to do plugs. Took me just over 2 and half hours mainly because the bolt holding down the battery try was frozen. Had to break the tray around the bolt to free it. Inners took about 3 hours rented a removal tool. I had a small issue on the drivers side but got it free. Just some set up work just to be able to start the job. Not bad for my first time and i got it back together with really no alignment issues.
LS460Crown (05-30-20)
#139
#140
Not many i had a shop do them in 2016 but they used Autolite. I would say i put around 30k on them. I just wanted to get Denso plugs installed again. It really is fairly easy.
#141
Actually the maintenance schedule specifies they be changed at 60k miles.
#142
Glad I could help LOL
#144
If i were you i would get replacement spark tube seals. If you find a bad leaky one too late than you have to stop or do over again. Its the round seals you have to pry out to get some of the coils free. A set of 8 is around 25-30 dollars.
ALK (05-30-20)
#145
Good tips. I didn’t even know these were there. Thanks!
#146
My car gets 27 mpg going 30 miles on the hwy. I don't know when the plugs were changed last but, I've had the car for over a year now. I do have a new set of Denso plugs but the question is, When do you know the plugs are going bad? She runs great now.
#147
If your car is burning oil change the plugs early as they will foul the reading causing a misfire .
The following 3 users liked this post by Taran:
#149
Wow, tint came out great.
