Things I did to my Ls460 today
Old 04-10-23, 03:43 AM
  #316
ausLX
ausLX's Avatar
Originally Posted by Gerf
Can you still keep that key in your wallet? also looks like you have a moisture problem.
I don't keep it in my wallet, it goes in the little coin pocket thing I have in most of my shorts. What do you mean by moisture problem?
Old 04-10-23, 06:22 AM
  #317
Gerf
Gerf's Avatar
It looks like the key card is wet in the pictures. Ya the sleeve would be a good idea for shorts weather, that didn't come to mind because it's still winter here.
Old 04-10-23, 09:24 AM
  #318
ausLX
ausLX's Avatar
No that's actually the original finish wearing off from the card. Which is the reason I started searching for, and found, a solution to cover the card itself. It has actually been through a washing machine cycle though, i just took the battery out and let it dry and it still works fine.
Old 04-12-23, 12:48 PM
  #319
Gerf
Gerf's Avatar
Swapped back to summer tires(all season) did an oil change, trying out amsoil 0-20 and their version of the trd filter ptr43-00079 which I'm sure is made for them by the same company that supplies TRD but twice the price. most expensive oil change I've ever done for myself.
Washed the car and headed straight down to an industrial area by the river where I like to hang and play poker with hobos.
The following 5 users liked this post by Gerf:
Boomin (04-12-23), Jsico (04-12-23), NiceLS460 (04-12-23), RSJSC400 (07-13-23), Spartan117 (04-12-23)
Old 04-13-23, 08:06 PM
  #320
Duck05
Duck05's Avatar
Finally got the wind shield replaced on our 2014. There was a crack that evidently was obstructing the rain sensor so the intermittent wiper function was not working properly. There also was a large star crack that expanded to a 12-13 inch line right in the drivers vision so had to be done.
We have AAA so it cost the deductible ($50) instead of the $700 plus it would have been. AAA contracts with SafeLite. They would not authorize OEM glass which would have been $650 more.
The tech was experienced, courteous, and did not mind my observations and a few pictures. The new “gel pack” over the rain sensor resolved the issue with the intermittent feature. Overall an involved process with a good result.
Staging replacement.
Part identification sticker.
Old wind shield removed and prepping begins.
Swing arm device in place.
New wind shield lowered in place.
Boomin (04-14-23)
Old 04-13-23, 08:27 PM
  #321
swfla
swfla's Avatar
Received 1,282 Likes on 991 Posts
A recent post here about windshield replacement and removing trim clips and drilling out rivets, then putting all new ones in. If this isn't done, there's a chance that the trim strips will come loose or not seat properly causing wind noise. Look very carefully at gaps around the trim. If uneven from side to side or not flush, you may wish to discuss this with Safelite.
Old 05-02-23, 06:48 AM
  #322
ausLX
ausLX's Avatar
I just installed the inverted shifter mod from JVE's Garage website. I got the link from a thread I came across here recently, but I forgot which thread and who posted the link. So thanks to whoever it was, it is such a good cheap mod, and I always thought the "manual" shift mode was the wrong way around. Still trying to remember that up is down, and vice versa 😆
I also have Vline2 now. Worth it, just for being able to use Waze alone. It's probably paid for itself with the fines I've managed to avoid. But having internet radio is great too.
Old 05-02-23, 01:23 PM
  #323
Sherl
Sherl's Avatar
vine2 is consistent on connectivity? I dunno if its for waze prolly phone mount is all it takes for me.
Old 05-02-23, 10:47 PM
  #324
ausLX
ausLX's Avatar
I cant connect wirelessly since i have the wrong version of android and can't roll back the update. So I have to connect via USB and keep my phone in the glove box, but I don't need to touch it while driving anyway. Not really any issues there except sometimes android auto doesn't auto activate when I plug the phone in. I just unplug and plug it back in and it usually starts right up. Not sure if that's an android auto fault or vline2
Old 07-14-23, 02:42 PM
  #325
Spartan117
Spartan117's Avatar
Replaced engine air filters and cabin air filter.
Replacement filters I bought from Park Place Lexus dealership (DFW area) are of inferior quality compared to replaced filters installed by Sewell Lexus dealership (DFW area) during 50k miles CPO service.
Old 07-14-23, 02:46 PM
  #326
swfla
swfla's Avatar
Are they OEM? If so, it's a shock to think standards have changed.
Old 07-15-23, 01:52 PM
  #327
Spartan117
Spartan117's Avatar
Yes, there are OEM - "Genuine Toyota/Lexus" was printed on the box and I did a local pickup at Lexus dealership.
Old 07-15-23, 02:33 PM
  #328
Gerf
Gerf's Avatar
They're using filters from a few different sources now, still oem but not the Japan oem.
I bought a cabin filter and air filters when I bought mine, the cabin filter was only about $10 and I thought I was getting a deal but it was so thin the peaks of the folds were drooping in spots so I ended up turfing it. The air filters were ok though.
The one I'm using is a quality filter installed when I go it, I don't even know if it's Toyota because I didn't see the box
swfla (07-15-23)
Old 07-15-23, 02:36 PM
  #329
Received 1,223 Likes on 909 Posts
Standards have changed from what I have noticed, I stopped buying denso for my cars.
swfla (07-15-23)
Old 12-24-23, 02:02 PM
  #330
ItalianMf9
10th Gear
ItalianMf9's Avatar
OEM mats all the way around and Continentals Purecontacts put on. So far so good.
Quick Reply: Things I did to my Ls460 today
