Things I did to my Ls460 today
The following 3 users liked this post by Muddy:
myw (11-12-19)
#79
#80
When I first purchased it I thought it should have a wood steering wheel, instead of the FSport wheel. With a little more research I found that the interior is correct. I bet it would look great with piano black trim.
bigsherv (07-26-19)
The following 2 users liked this post by Kuhan:
bigsherv (07-26-19),
mikesrx350 (07-27-19)
#82
Sorry. I am confused. I thought all of the FSports had the piano black and aluminum trim. Did yours come with wood or did you swap it with another trim?
#83
His is a crafted line. The crafted line F Sports have the shimamoku wood.
#84
Washed and waxed
The following 4 users liked this post by mikesrx350:
#85
Reinstalled Lexus Logo puddle lights that Lexus of Tulsa removed when they installed new front door panels yesterday. Quick and easy.
Dennis
Dennis
Ogun360 (01-20-21)
#86
The following 4 users liked this post by Mikerx80:
#88
Picked up some new shoes and socks for my baby, a set of 20" staggered rims and tires, 9 x 10.5, nearly NIB absolutely pristine.
It was a 5 hour round trip drive to Chicago and back to get them but well worth it.
Been looking for several months now for a set and can not wait to put them on.
Tomorrow I will wash, de-iron, clay, wax and ceramic coat them before I install on the LS. Pictures to follow....
#89
Last week, I personally did (accept for the tires/alignment), I was on vacation..
1. Changed the front breaks. Warped rotor all good now !
2. Used the Sea Foam spray on the air intake to try to clean up the motor a little (cleaned up the throttle body really well in the process)
3. While the car was up, checked the front end for play, solid as a rock.
4. Secured the lower panel with some screws, over time, the screws holding the plastic cover under the motor drop out, so it flaps a little... Anyone know where to get more ?
5. Replaced the front tires, and an alignment, pretty warn down..
6. Changed out the YELLOW fog lights for some white LEDs (suggested here)
7. Changed out the Nike Lights to LED as well (after changing the Fog lights, the yellow Nike lights looked even worse, these were also suggested here).
8. Washed and and really cleaned the car.
Ogun360 (01-20-21)
#90
Changed the spark plug with the plug seal . And NEW RH catalyst . All good now .
