Clunk front right & VSC Light
EDIT: Driver's side front end clunk. Not right.
Hi all,
A couple questions for savvier folks than me. I recently bought a 2010 air-ride enabled LS that's great, but I am chasing some stiffness in the suspension that I want to get resolved before the 30 day warranty expires from the dealer (a reputable dealer, and I'm on day 23 or so). The problem I'm experiencing is that when I roll over really average everyday rougher roads, I get a lot of rigidity coming through in the suspension and a bit of clunking/noise coming from the front end. I have also had the VSC light blink a few times in the first 500ish miles I've driven with it and under very normal driving circumstances. I'm thinking that a sensor could be dirty or going bad for the VSC, but the noises make me worries that the air shocks could be showing their age. I bought a service contract with the car through my credit union that covers ALMOST everything, but that doesn't cover the air ride shocks. Said differently, if that's the culprit I want to get it done on the dealer's dime before I rely on the warranty.
Any ideas what might be causing these symptoms? The dealer already replaced the end links when I mentioned the noise, so that's not it. I also feel like the dealer is going to balk at any major repairs to maintain profitability (if the suspension needs replacing) and do what they can to kick the can down the road and let the warranty elapse. I'm bringing the car back this Thursday for service, so I'll be interested to see what they say. Should I be bringing it to Lexus directly and have them change the oil, along with making mention of the issues? They'd then drive it and be able to do a better assessment.
TIA.
Hi all,
TIA.
Either way, if they find nothing I'd find that a bit suspicious and would plan on bringing it over to Lexus for an oil change and a very thorough inspection.
I think you have two different issues. (1) ball joints: have the dealer check them. If your getting clunking when going very slowly, say pulling in a driveway or into the garage, that might be ball joints. (2) I think the stiffness is an issue related to your air suspension. Do you notice any difference in comfort mode versus sport mode? If not then the air suspension is not working properly. I believe it will default to the stiffest setting.
erkelbot (06-13-19)
Update: They ran diagnostics and there is a bad wheel speed sensor for sure. They have a former Lexus tech there (it's a VW dealer) who will be evaluating it thoroughly this morning thoroughly to ensure all else checks out. I'm having them check brakes, arms, air ride, etc... If the findings come back inconclusive -- aside from a wheel speed sensor, which would not cause a clunk -- then it's time to jet over to the Lexus dealer for a very thorough inspection. My local dealer doesn't offer inspections, but they do a fairly good and thorough inspection when you have ANY work done there. That means, an oil change and a "concern" about the suspension should trigger a test drive and diagnostic.
ben9
12-21-11 11:35 AM
