window glass folds outside rubber seal
Old 06-10-19, 02:08 PM
2v1g
2v1g's Avatar
Default window glass folds outside rubber seal
Mine is 2011 LS460, so I don’t have the typical window noise issue of the earlier models, but my side window glass folds / warp a portion of the outside rubber window seal when I roll up the window. Is there any good solution to fix the issue?
Old 06-10-19, 02:57 PM
Received 2,715 Likes on 1,944 Posts
Will most likely have to replace the window seal
Old 06-11-19, 08:24 AM
2v1g
2v1g's Avatar
Does silicone lubricant help? Is it because the front double glass is too thick and leave little gap for rubber seal or because the glass doesn’t raise up to the proper position? The issue happened on the front passenger side first one year ago. Now it happened on the front driver side too.
Old 06-11-19, 09:51 AM
sha4000
sha4000's Avatar
Most likely the strip is worn. Straighten it out with the window down and see if it takes the original shape.
Old 06-11-19, 10:10 AM
ShaneAlan
ShaneAlan's Avatar
I wouldn't mess around, just go buy some new ones..
Old 06-11-19, 10:43 AM
2v1g
2v1g's Avatar
It takes the original shape.
Old 06-11-19, 11:28 PM
jdanielca
jdanielca's Avatar
i wonder how much that costs....
finding the part number for that is going to be "fun"
Old 06-12-19, 11:13 AM
jdanielca
jdanielca's Avatar
Originally Posted by FunFact
I believe it’s $100 for the part itself. Installation is probably worse, as it’s not a simple plug and play.
Well labour here is cheap enough I just need to locate the part number on lexuspartsnow.com which is a pain.
define : not a simple plug and play I assume various parts of the door has to be removed.. is that what you are referring to ?
Old 06-12-19, 01:03 PM
nguyenpt12
nguyenpt12's Avatar
Had this happen to me, it wasn't covered under CPO but Lexus did it to me as a courtesy since the car was only a month old to me. i think the bill came out to 700 dollars for 1 window
Old 06-13-19, 06:42 AM
2v1g
2v1g's Avatar
$700 per window is too much....
I find that only happened to thick glass, My rear single glass is fine. Also the thin glass on my Rx350 never cause any issue.
Old 06-13-19, 01:20 PM
sktn77a
sktn77a's Avatar
It's the front window track - about $100-$150 for the part but removing it involves drilling out rivets and installing the new one involves riveting everything back into place. Hence the labor charge.
Old 06-13-19, 01:29 PM
nguyenpt12
nguyenpt12's Avatar
look up window run on lexusparts and you should be able to find what your looking for looks to be around ~100 dollars for the part.
Old 06-13-19, 01:42 PM
2v1g
2v1g's Avatar
just Ordered Honda 08798-9013 Silicone Grease from ebay and will give it a try.
Just apply inside the rubber seal?
Old 06-14-19, 06:23 PM
DavidinCT
DavidinCT's Avatar
For those prices, crap you can buy a used door !
https://www.ebay.com/itm/07-08-09-10...UAAOSwSvtcfqmA
$170 for the full door with the trim...
Old 06-17-19, 06:33 AM
2v1g
2v1g's Avatar
Then you have to paint the whole door
Quick Reply: window glass folds outside rubber seal
