View Poll Results: Brake Actuator Failure / Fluid Change Status
Actuator HAS Failed : NEVER Changed Brake Fluid
12.79%
Actuator HAS Failed : HAD Changed Brake Fluid Beforehand
10.47%
Actuator HAS Failed : UNSURE on Fluid Change Status
15
17.44%
Actuator HAS NOT Failed : NEVER Changed Brake Fluid
15
17.44%
Actuator HAS NOT Failed : HAD Changed Brake Fluid
21
24.42%
Actuator HAS NOT Failed : UNSURE on Fluid Change Status
15
17.44%
Voters: 86. You may not vote on this poll
POLL: Brake Actuator Failure > All Please Respond
Year of LS460: 2008
Current Mileage of LS460: 98K
Year/Mileage of Fluid flush/change: As scheduled; changed about every 2 years
Year/Mileage of Actuator Failure: No failure.
icon901 (06-20-19)
My 2007 LS460L had the actuator changed out at 8,000 ish miles per the Lexus Driver's site service notes. I purchased the car a few months ago with 103k miles and about a month ago it started to make a squawking or barking type of noise when applying the brake. Per my research, I may have air in the lines. I plan to do a brake fluid flush soon to get rid of that noise.
icon901 (06-20-19)
Year of LS460: 2008
Current Mileage of LS460: 99K
Year/Mileage of Fluid flush/change: History shows routine service visit to dealer
When I got my LS460 in May 2017 the fluid looked clear. I've been doing a brake reservoir 16oz flush and fill every year. I use only a sealed bottle and never anything sitting on the shelf that was previously open. I also bought a new brake reservoir cap, the original one no longer felt like it was sealing properly.
Prior to doing the above I heard a faint squawk sound. The only occurred when I was parked on a steep decline driveway and pressing on the brakes somewhat hard. It was also below freezing at the time and I discovered my fluid was a little low. No noises after I refilled it to the proper level.
icon901 (06-20-19)
A quick search will bring up a ton of threads where it's gone over with much more detail.
LS460Crown (12-04-19)
Trying to keep this thread to data points and avoid getting into the same discussion that has been had a bunch of times in other threads... but short answer: noise isn't a clear indicator of pending failure, and failure is obvious (Dash lights up with warning lights).
2007 LS460L 2nd owner.. purchase car with 54k miles on it.. first owner was notified for brakeactuator check notice Corporate told me.. they did not respond.. car has 65,000 miles on it now.. no issues don't know if the brake fluid was changed or not.. car has been to four different Lexus dealership always come out with flying colors...
I'd be curious to hear from the few unfortunate owners that have experienced failures of the ABS actuators.......How much did it cost to replace? Did you have it done at an independent shop or the dealer?
2011 LS460 AWD: Experienced abnormal braking with less than 20k miles. Extreme hard pedal and soft pedal at times, as well as brake noise (loud grunting and pulsing.) Oddly, this only happened after continued heavy stop and go traffic. Per dealer instruction (TSB), had fluid flushed twice. Then had brake actuator replaced at 36k. Since then...no issues. Also had all new rotors, pads, hardware and calipers serviced at 1,000 miles after actuator replacement. Dealer charged me $1k for actuator replacement, as they could not replicate hard and soft pedal. But, mysteriously, all symptoms went away after replacement. By the way, Lexus Customer Service was absolutely useless to me. What a disappointment! Anyway, car now has 45k on the clock.....no issues.
Had my 2007swb for just under 2 months so far and....
Year of LS460: 2007 swb
Current Mileage of LS460: 173xxx
Year/Mileage of Fluid flush/change: haven't changed
Year/Mileage of Actuator Failure: presently sitting at Lexus of Maplewood (Minnesota), eagerly awaiting official diagnosis of both my brake actuator assembly issues, as well as a nice Mark Levinson
amplifier issue for good measure. Got the dreaded chirping through the speakers and a week later, started experiencing terrible sticky braking and the lovely 5 dash lights... Stay tuned for official Lexus diagnosis (@ 2 seperate $158 diagnosis fees, of course...)
winterturb (06-29-19)
Year of LS460: 2011
Current Mileage of LS460: 85K
Year/Mileage of Fluid flush/change: changed at lexus suggested intervals
Year/Mileage of Actuator Failure: Failed in 2019
Year of LS460: 2010
Current Mileage of LS460: 77124
Year/Mileage of Fluid flush/change: Flush at 75k by dealer in FEB 2019
Year/Mileage of Actuator Failure: Hasn't failed
My dash lit up with all warning messages at 59k miles. $3,100 to repair since out of the warranty enhancement period. Absolutely no goodwill assistance from Lexus after speaking with a case manager.Very disappointed in their lack of empathy for this known safety defect. Reported this as safety defect to NHTSA.
The following 2 users liked this post by supraguy:
LS460Crown (12-04-19),
SupraTurbo (09-30-19)
My 2006 ls460 had the actuator fail @ 75,000. The dealer replaced the actuator @79,500 in Nov. 2015. I used my extended warranty that I had purchased in April 2015.
Now June 2019, this same ls460 with 103,000 miles has another failed actuator.
Lexus won't do anything about it. And I no longer have the extended warranty. Even though there was that 'recommended service' or some kind of quasi recall for the product.
Seems odd that 2 actuator go out in the same vehicle.
Any advise? And is the vehicle deemed safe to drive without changing the actuator again? The car still drives great and I still love it.
Snapshot at this point:
NEVER had the brake fluid changed: 53% had failures
HAD the brake fluid changed: 14% had failures
78% of the failures had never changed their brake fluid.
VERY small sample size still, far from conclusive.... but interesting. Let's keep this going.
