Climate Control Only full hot or full cold, 08 460L
Hello everyone, I purchased a 2008 LS460L 3 months ago with 208k miles, I am having a strange issue with my climate control, the vents in the front and back of the car are only blowing either fully hot or fully cold air and no in between like any other AC system i have had. The car has the 4 zone climate control, I have replaced both front and rear cabin filters and fixed the recirc door, as it was popped off due to someone forcing it up at some point. I have gone through the car with techstream to sort other issues and i have never seen any codes in the climate control computer other than B1421, B1424 and B1428 which are the solar sensors and i have read that is normal if it is dark outside when you scan it, if I'm wrong please let me know. I stumbled upon a climate control servo calibration in the utility of techstream so i did that and i didn't hear anything abnormal coming from the mix box servos and they all sounded smooth.
i would like to know if anyone here has experienced anything like this, or if their car is the same and that is how lexus did these cars for some reason
thank you!
thank you!
Clearly there is something wrong, Lexus didn’t design it this way. It may be the air mix servo motors that control the air damper. I have replaced them in my Lexus RX. Look here.....
https://www.clublexus.com/forums/ls-...rvo-motor.html
thank you!
thank you!
Sounds like a feature.That's how I keep mine 365 days a year and just hit Off when I've had enough. Keeps it exciting. Sometimes I put it on Dual for the wife on those rare occassions she's in the car.
