Ls460L lights went out on dash next to nav
Hopefully someone more knowledgeable than me can chime in.
Well as with everything, always try simplest things first.... which is a battery reset disconnect let it sit an hour or so reconnect, that's what I would do if it did not fix it, that means it is nothing got to do with setting or a silly malfunction in the system, likely the LEDS behind those buttons have failed. I have no idea how the elds works on those panels.
I'm not sure if you already fixed this issue, but I had a similar problem that another club lexus member, @2slow was able to fix. The LED light behind the DEST button went out on my 2010 LS460 and he was able to pull my navigation unit out and replace the LEDs which resolved my issue. If the buttons still function and it's just the backlight out then I would suggest sending him a message.
