You can run a 245, a 255 or even a 265, the size difference is about 1cm in width and .3cm taller between each step. Basically not going to make any huge difference.
....just looks-wise it will.
OP, there are several wheel threads around and quite a bit on Instagram if you use the hashtag #ls460. I've reached out to quite a few ppl on IG that are as far as Japan who have DM'ed me back with wheel and tire specs.
when i had my 22's, i ran 245.30's the first time. the following times i ran 255/30's. didnt really see much difference. I probably just cant drive with 22's because every time there would be bends and a crack here or there.
With 265/30, it sits 1" higher than oem. Does the car has air suspension or lowered? If not lowered, then it should be fine. I bought a set of 20" Asanti wheels too. Should be here tomorrow from Tirerack.
I’m riding stock suspension.
What model Asantis did you get? Post a pic if able.
I bought the matte graphite ABL 14. The wheel size is 20 x 9 +35mm all around. Tires are Pirelli P7 Plus 245/40/20. My wife drives the LS now so I don’t want to go too crazy with bigger sizes.
Nice! I almost went with those. I really like the finish, wish the ABL 24 came in that finish.
