Should I buy a well-maintained 2009 LS 460?
looks like a nice car
if you want an ls 460 I personally would look for one in the southeast that was owned by an older person and maintained.
to me, the roads and buying a used car in the north east is not what I do,
just 2 cents
just 2 cents
If you can get them down to 6 or 7k I don't see how you can go wrong. However you should only buy a car with this many miles if you are willing and able to diy the maintenance as much as possible. I have an 08 with 251k and its been very reliable and I picked it up with high miles and a great Lexus service record. I don't recommend financing either. But I suppose you could be financing a Mazda or something for 25k so you could be worse off! On the plus side if you can keep it running it really won't depreciate in value much more. Its promising that its last owner was actually having it serviced at Lexus dealer as of May at 199k miles where it had its scheduled maintenance done. The seller knows very little about the car apparently which should be an advantage to you!
