Non-ml speaker upgrade!
HELLO ALL! I am interested in replacing some factory speakers with aftermarket. Ive googled around and cant find too much info regarding non-ml upgrades. first speakers onb the list would be front door speakers 6x9. factory sub? dash speakers?
I cannot answer your questions regarding speaker sizes, but I can say that, generally, aftermarket speakers won't work well as drop-in replacements to OEM systems. Most OEM speakers are very light and have low impedances. You typically would have to replace the OEM amplifier with an aftermarket amp to drive the aftermarket speakers.
Something wrong with your speakers, or you just looking for louder boom? Problem with these OEM setups is that these speakers, amplifier and your head unit is one system that was designed as a whole. Replacing speakers alone would not do you any good, it can actually make your audio worse. If you interested in upgrade you have to consider replacing OEM amplifier first. You need to find aftermarket amplifier with built in DSP and enough channels and power to drive all your speakers and capable to communicate with your car (your controls on the steering wheel, nav voice guidance, bluetooth and such goes through this amplifier). Then find appropriate speakers to match your new amplifier. Since aftermarket amplifiers don't have that many channels as your OEM amplifier you might have to run some speakers in parallel on one channel with additional crossovers. Last time I was upgrading my car I ended up replacing one OEM amp with two aftermarket units. I had Audison AP8.9BIT with one additional 2 channel amplifier for the subwoofers. I also ended up doing complete soundproofing from top to bottom. It was such a pain in the back, I ended up having entire car stripped to the bare metal. LOL
Look at Crutchfield,com. You enter your car and they give you a selection of speakers I will say from personal experience that the dash and front door speakers give you the best bang for your buck. The others don't impact your ears as much in reality but on paper it seems they matter equally. As far as the sub goes, a powered, boxed 10" in the trunk is quick and easy. Produces good results. Again, from personal experience.
For future posts, it's helpful to have year and other info on your car.
I've replaced the front and rear door speakers, added a sub w/amp and line out converter and it's quite an improvement over the base stereo. You need a Metra bracket for the 6x9's in the front and rear doors use the oem brackets.
Probably will do the dash speakers next, the are 3.5's like the back doors, there are existing holes in the rear doors that can have 6.5 in mounted with wiring that runs to the amp area but unused on the pioneer amp.
Mark Levinson models use 8 ohm speakers vs the Pioneer (Base) speakers that are either 2 or 4 ohm. It's hard to get a good sound out of aftermarket speakers on the stock amp even if they are still 8 ohm (hard enough to find as is), because the amp has built-in crossovers that are designed for the speakers it is specc'd with. You'd be better off gutting the stock system and putting in an aftermarket amp and speakers.
I've had a Toyota with JBL and a 400 with a nakamichi also test drove a 460 with the ML and didn't really think any of them was anything special but one mans ACDC is anothers Milli Vanilli.
I agree replacing it all would be best but then steering controls would be a struggle.
XxGoKoUxX
03-08-17 11:36 AM
sarah
07-22-09 10:01 PM
