I知 getting an electrical warning on my display....
It is a 2008 LS460. When accelerating with heated seats on it sometimes skips a beat (engine), heat stops for a second or two and the radio stops momentarily.
What could it be?
TIA
What could it be?
TIA
This may be an indication that the car痴 starting battery is defective. If your battery is more than a couple years old, you should replace it, and see what happens then.
I had a similar problem. I had my battery checked and discovered the positive battery cable not tight. Cables tightened and never had that problem again.
jmcraney (12-04-19)
