Please help, Power steering fault C1552 Power supply voltage
I'm confused. In the pdf it is labeled a power steering ecu. In the picture ( wire diagram) posted a few posts above it is called a power steering converter assembly. In any case I've replaced that one under the hood on the right side of the engine compartment. There is another one on all base 460's right? According the the wire diagram above there is a power steering converter assembly and a power steering ecu.
Thank you Sha4000! With the pdf's you posted it is pretty clear I mixed up the box names. I changed the ecu not the converter box. Time for me to order a dc to dc converter box.
Thanks again!
Thanks again!
EricAdams
01-26-09 06:38 AM
