Cold Cup Holder...
Cold Cup Holder...
My 2008 LS 460 has a very cold cup holder. When I recently went on a long trip and put a hot cup of coffee in the cup holder it turned it stone cold.
Is this a feature and if so, how do I turn it off so all of my hot drinks are not cold ?
Thank you!
Thank you!
Cup holders in the LS are not heated/cooled unlike the S class. However, the ducts supplying air to the armrest vents may pass right around the cup holders. Try running warm/hot air to those vents and see if it makes a difference.
You should check what the rear AC vents are set to. Make sure that the center armrest vents are blowing warm or hot air. If your cup holders are still very cold, then you should get it checked out.
I have never even noticed this happening in my car. I have realised that my centre console gets cooled down to whatever temperature the air con is set to, but have never had any problems with the cup holder. Makes me wonder why some people have this problem and some don't?
You guys with cold cup holder should pull out your centre console and see what is going on under there.
