A/c compressor ?
I noticed today that My ac has stopped working the fan blows the air but the ac dosent seem to engage no cold air any idea on what can be the reason... a bad compressor or a blown up fuse/relay if anyones knows the fuse number that would be a great help
Thank you
Thank you
These cars are so complex that sometimes you dont even know whats gonna happen next lol .. will take my car soon to some good shop and see what can they say about the leak .. that was alot off help with the self diagnostic method you told me about thank you for it
The following 2 users liked this post by sha4000:
Markw4mms (01-16-20),
Thegamemhb (01-15-20)
update
First of all once again a huge thanks to sha4000
after getting the codes details i.e low freon i went to a local shop they told me there is a leak in the system . It was the ac compressor washers that were leaking got them fixed today and ac is running good
sha4000 (02-13-20)
Ok so i need to give some details here the first shop tried to find the leak and said that my evaporator is leaking and they will charge me 800$ i was not sure if he knows whats hes saying so i left and went to the other shop. They were able to find the leak and charged me 300$ just to remove the 2 washers and fill the freon i left from there and ended up at one of my old friends garage he charged me 30$ for fixing the leak and charging the freon
So the first shop basically tried to scan you then the second shop actually found the problem but was charging too much in your mind. You then went to your friend and told him what the issue was and he helped you out which only costed you $30. If so then I applaud your efforts at saving money while getting the problem resolved.
