HELP! 07 LS460 ECB warning check parking brake! C13AF
In my case this parking brake module fixed my parking brake messages and C13af code. After replacing the module I cleared the codes with techstream.
https://www.ebay.com/itm/07-17-LEXUS...0AAOSwaF1gGJ11
The module is fairly easy to access in the trunk. You can take it out and inspect it for water damage, seems to be common. I also had to replace the 30amp fuse.
