Rear Fog
#61
LMFAO, well you asked for comments.
Fortunately, I haven't had to dig into this area but am seeking knowledge as usual when it comes to our cars. As you mentioned, 82730-50150 is not found in the Lexus parts sites I normally use; however, on ebay here quite a few show up for sale: https://www.ebay.com/sch/i.html?_fro...50150&_sacat=0
#62
82730-50150 is a part number of a sub-assembly. The actual part number is 82730-50190, which corresponds to 2007 LS460(L) Canada spec.
#63
hmmm how is that a sub assembly oh well I’m not getting it, my car is a US spec car, ive tried the German part number listed above, guess I have to wait for the body ecu experts to share what they know.
#64
It is a sub-assembly because the box itself does not constitute a whole part (see the picture below).
Your VIN number was used to generate a list of compatible parts. The part numbers say that you have Canadian spec, US spec has a different part number for the block.
#65
It’s a bad site I think, it’s not possible I have a Canadian spec car because I have miles lol when u click details there are more options
#66
Officially there are 4 destination codes, USA, EU, JP, and general but I know there are still some parts marked as Canada spec.
Realistically I'm not sure what the region differences could possibly be because our road laws are very similar. Usually Canada spec cars just have extra rubbers and stops to prevent icing over.
#67
There is also Korean spec.
#68
jdanielca (10-05-21)
#71
Is having the rear fogs on a separate line from the fronts a must? If no, I'd tie the rears into the fronts and just have them come on when the fronts do. If you need/want them independent then ignore me.
#73
I hear ya. Unfortunately I have zero CAN, CAN interception, decoding, and sending experience which sounds like is the crux of the problem.
#74
There still is a chance in getting this to work properly. Someone would just need to first figure out if there were and LHD LS460's made with rear fog. Then probably buy it new because the odds of finding a used one are basically zero. This should eliminate the mirror and window switch issues of putting a RHD fuse box in a LHD car. Then you would be left with a working rear fog and celcius HVAC display.
As far as finding the CAN signal that activates the rear fog lights you would need a scanner on the line to grab that line of code which shoots out when you turn on the rear fog light. That's the easy part. The hard part would be figuring out how to even inject that line of code when you flip the switch, or flash the USDM CPU/chip to enable rear fog. I can't even think of a scenario where this would even be worth it lol. Going to install my $18 wireless remote/relay and be done with it.
