2007 Navigation Freezes
Hello all:
Recently my navigation has been freezing up on a consistent basis. It appears as if the GPS is still working; however, the map won't fully display. At first, it wouldn't display anything under a quarter mile; now I see no map at all. Today it was actually locked up and flickering.
Anybody else encounter this issue? I'm thinking that it needs to be reinstalled; however, I'm not going to use it for navigation. I do like having access to a map though when using the phone isn't an option.
Thanks!
Thanks!
I have a 2007 and my navigation screen would not load unless I rebooted the system by disconnecting the battery. Apparently, the navigation system utilizes the hard disk drive in the car. These drives do fail, as did mine, and they have to be replaced. I had mine done by The Lexus dealer in December 2018. I think the total bill was about $1300. It’s a dealer only item. I’m inherently cheap, and I couldn’t find an economical solution. The navigation system in the car is terrible, and the 2007 map makes it even worse. I do like seeing a functional map while I’m driving though, and that’s why I spent the money to fix the hard drive.
Good luck.
Good luck.
Good luck.
Good luck.
I know; it sucks. Maybe you can get by with e reload, but that’s not cheap either. I looked into that as well. After a lot of research on this forum, it looks like you can only get that done at the dealer, and they want around $350 for that service. Of course, you get the newer map package, if it works. When I got my new hard drive installed at the dealer, it comes with the navigation installed on the drive. You would think that if you spent $900 on a new hard drive it would come with the latest maps; but think again. My new hard drive from 2018 is loaded with the 2007 maps.
It is just a heavy duty HDD. In my research I read a lot of posts about people, apparently a lot smarter than me, trying to come up with a solution, but none of the posts ever recorded anyone ever reaching a solution. IIRC, the disk formatting and software is all proprietary. Even the super techie guys that were trying to port format and software over we’re hitting a dead end.
It would be cool if you could figure it out as all the HDD’s will eventually fail.
giaruso
ES - 7th Gen (2019-present)
04-15-24 02:48 AM
whyster
ES - 6th Gen (2013-2018)
08-24-19 05:19 AM
