Sway bar links
Sway bar links
Has anyone had their sway bar links replaced and how much were you charged? I have a 2008 ls and was quoted $442 by my local Lexus dealer. Debating whether to go to Toyota dealer or independent mechanic
texas008 (01-12-24)
OEM links are like $92 x 2= $180. They are basically charging you 2 hours labor for a job that should only take them 15 minutes to do on a lift. I bought links off Ebay when I was doing the lower control arms.https://www.ebay.com/itm/Front-Suspe...72.m2749.l2649
The links are a real basic part so there's no need to use OEM especially since hardly anyone is buying OEM controls plus the Ebay links have a nut on the bottom which makes it easier to install/remove. With The OEM links you have to use an allen key to keep the ball joint from moving while you use a wrench to turn the nut.
texas008 (01-12-24)
PTYIS2
IS F (2008-2014)
05-05-18 12:37 PM
