07 LS460 front hub torque and brake questions
Does anyone know what the torque specs for an 07 ls460 front wheel hub is?
Also im doing my rear brake pad and rotors soon do i need to disconnect the battery? I also have a copy of techstream if someone can point me in the direction of relieving pressure from the rear brakes?
The hub bolts are 48 foot lbs. I've changed brakes and rotors without disconnecting the battery but the manual recommends that you remove the negative cable. If you don't remove the cable and press the brakes without any resistance ie. rotors or pads, you might have to clear a bunch of codes as well as other issues when starting the car. I had this happen but I have TS and the help of this forum to get things back to normal. If you were just changing pads I would not disconnect the cable but since you are removing rotors also I would disconnect it for peace of mind.
truviethug (04-09-20)
thank you!
texas008
03-30-16 04:32 AM
