External Mirror and Reverse
8th Gear
Thanks for your patience ...
The external mirror on the passenger door.
When I put the car in reverse, the mirror tilts up.
Is that how it should tilt?
I was thinking when I put the car in reverse it should tilt the mirrors down, to give me a better view of the parking lot markers.
Perhaps there is a wire installed backwards.
Your thoughts are appreciated.
Car: Lexus LS260 (2014)
When the car is in reverse, you can re-adjust the mirrors, and those settings will save for the next time you put the car in reverse. What happened was at some point someone adjusted the mirrors up while it was in reversed.
So just put the car in reverse, tilt them down where you want them and next time you put it into reverse they will tilt down to that position.
jmcraney (04-10-20)
Thanks for the tip!
No problem!
Thanks for the tip !
8th Gear
thank you much
Headed out to adjust the mirrors!!!!
thanks
I live to serve!
dbs600
05-16-14 08:52 AM
RA122022
RX - 3rd Gen (2010-2015)
06-05-12 10:16 AM
