Transfer Case Drain/Fill Plugs Location?
Hi All,
I am doing the tune-up for my LS 2009 and the transfer case fluid replacement is on my list.
Could you guys please take a look the transfer case unit picture attached and tell me where to locate fill/drain plugs?
This is the fluid that I'm going to use for transfer case since this fluid is the same as my rear differential fluid.
https://www.autozone.com/greases-and...quart/1437_0_0
Please advise.
Thanks
Please advise.
Thanks
Hi All,
Please advise.
Thanks
Please advise.
Thanks
https://www.clublexus.com/forums/ls-...iy-w-pics.html
sha4000 (04-16-20)
https://www.carman.guru/en/unitschem...3&unitId=59240
I'm pretty sure that the top one to the right is the fill plug and the one below and to the left is the drain plug. They both use 10 mm/ hex sockets. The one all the way to the left is for something else as I'm sure that plug is bigger than 10mm. Take a look at the diagram. It's a bit confusing since it looks like the drain is underneath in the picture.
It's a little bit confused about the red I circled in RED.
Here's the actual page on the dealers website.
https://www.lexussouthatlantaparts.c...ring=transaxle
And another with a clear pic of that plug that's underneath.
Yes. I confirmed the upper right is fill plug, and the bottom green is the drain.
I was able to drain and fill the fuild. This is a 15 min job.
toantran99 (04-25-20)
Lexus97ES
14
01-12-17 08:11 AM
BNR34
11-08-14 04:54 PM
