Best Exterior LS Mod EVER!
Well not necessarily a "mod" but I think it's the best bang for you buck when it comes to maintaining the exterior of your LS. I just applied the CQuartz UK 3.0 kit to my car and boy does it seem like the day I drove it off the lot. Super glossy, durable finish with great protecting capabilities that can last up to a couple years, I ask myself why didn't I find this sooner. Pictures don't do it justice..
No filters on any of these pics. Easy DIY, just time consuming. You should really check out the product and invest in your vehicle.
The following 6 users liked this post by Acura2Lex:
DaveGS4 (04-27-20),
DavidinCT (04-26-20),
dlbuckls10 (04-26-20),
Duck05 (04-29-20),
Nospinzone (04-27-20),
and 1 others liked this post.
On the detailing forms some don't recommend the ceramic coatings. Look good and last longer. But like anything will eventually fail even with the maintenance steps. And this product needs to be completely removed to start over. You do so with a buffer and polishing compound. You will then remove some clear coat. This step best left to a professional since you can do some damage if dont know what you are doing. If not careful can remove to much clear coat.
I think it is good if you only keep a car about 5 years and don't have to deal with the removing. I keep mine long term so I passed.
Would like to see some more info and what people think of it 5 years or more from now. Before I consider.
But the car really does look great in your pics.
Like anything else, it doesn't last forever. And it doesn't have to be removed unless you want to remove it before its gone.
I've switched to only using ceramic coatings.
Yes, i would want to remove it. Would not want it blotchy looking with one area failing and the other still good and take years to wear off.
Where do people get this stuff?!
Thanks. Here's what I used.
Thank you. And sorry you are completely misinformed. SW17LS is 100% correct, it's just like a sealant or wax that just simply wears away over time so you don't get any blotches or weird defects. Think of it as the new modern wax that lasts 20x longer and durable as well.
You hit the nail on the head. I think some people just perceive the wrong information online with unreliable sources that have no actual experience with the product.
Nice job Acura2Lex!
Six years ago I used 22ple on my wife's 2001 Jag S-Type. I told her I was taking care of her car first, but in reality I used it as practice before I did my cars . I then did my LS and then my 612. The coatings lasted 5 years and my LS sits outdoors. As Steve said, as the coating ages the only way you notice is the way the water no longer beads.
Last year I used the Carpro Cquartz UK 3.0 on the 612 and the car looks great. The 22ple was fine, I just decided to switch. I didn't get to the LS, but that will be done soon (as soon as we get a little warmer weather here). After that I'll do the FF.
If you've never done it before there is plenty of info in the Automotive Care and Detailing forum and also at detailedimage.com as well as some other detailing sites. It takes me two full days, but that's because I'm meticulous and I go slowly since I'm not a professional. With the random orbit polishers if you take your time, follow directions and go easy, you won't damage the paint.
https://www.carceramiccoating.com/ho...yer-of-coating
This is just one source
Nice job Acura2Lex!
I'm the same way, I take my time because the best job done is the job I do myself. It took me close to 10 hours from start to finish including wash, clay, buff, polish, eraser, coating then reload + 2 days of cure time.
CQuartz is great, I have a few friends that have used it and praise it as well.
I've never used it firsthand but have used Modesta which I'm quite happy with, paired with XPEL Ultimate, it does wonders.
roadfrog
12-03-15 08:58 PM
