VSC & Check Engine light / P2241
One day after picking up my 2007 LS460 from the dealer after the 150K mi service, the VSC & Check Engine light came on. I tried a reset by disconnecting the battery for 30 minutes, but the light came back on after a couple of days.
Running the code, I found P2241, and discovered oil leaking around the valve cover at the fuel pump. I do not want to pay the dealer for this service; how much might I expect to pay at an independent shop to replace both seals, if I go ahead and replace both of the air/fuel sensors as well?
Thanks for your insight!
The only culprit for P2241 is RH side A/F sensor maybe oil contaminated the sensor . Or the sensor is bad and check the wiring .
MrDOS (05-22-20)
MrDOS (05-23-20)
400 maybe dealer price . Give me the vin I will double check .
Thanks - I'm just trying to get a picture of what an independent will charge - JTHBL46F175014827
89467-50020
Prices between 150 -200
sha4000 (05-23-20)
