3k Miles in 8 Months, Should I do Oil Change Soon?
Old 06-05-20, 06:42 PM
Spartan117
Spartan117's Avatar
Default 3k Miles in 8 Months, Should I do Oil Change Soon?
Due to COVID-19 I am not driving much. Bought a used 16 LS in October 2019 with 31.5k miles and now it has 34.5k miles. Drove only 3k miles in last 8 months.
Should I do oil change soon?
Would it hurt the engine if I do oil change at 5k miles but after may be 12 months? In my second and previous cars I hit 5k miles every 4 to 5 months and never went over 6 months without an oil change.
I would appreciate your input.
Old 06-05-20, 08:11 PM
dubsta1
dubsta1's Avatar
you should be fine
Old 06-05-20, 09:06 PM
Kuhan
Kuhan's Avatar
If it were me, I would change the oil at 5k miles or 1 year. I put less than 5k miles a year, so I change it yearly. But I’m a diy-er so it’s up to you. No issue if you want to wait until it hits 5k miles and charge the oil.
Old 06-05-20, 10:16 PM
Spartan117
Spartan117's Avatar
Originally Posted by dubsta1
you should be fine
thank you!
Thank you!
Old 06-06-20, 10:18 AM
Dave144239
Dave144239's Avatar
I change the oil once a year no matter what. I've only put 3300 miles on the car since the last oil change in May '19, but as soon as my mechanic opens up again I'll take it in for an oil change.
Old 06-06-20, 11:31 AM
mikesrx350
mikesrx350's Avatar
if your doing low mileage....
5k change oil at 11 or 12 month once year
normal driving combo city / highway go 6500-7500 miles with a good synthetic and a good Toyota oil filter
if you using a not as good oil filter, then change between 5-6k
and penzoil platinum is the best to run in our cars. will go easy 10k I change mine 7500
good luck
Old 06-06-20, 04:13 PM
Received 2,730 Likes on 1,956 Posts
Plenty of good oil you can run in our cars, no specific reason Pennzoil Platinum is "the best" outside of personal opinion.
Old 06-06-20, 04:17 PM
TANORWAY
TANORWAY's Avatar
Lexus says 9000 miles or 12 months.
Old 06-06-20, 04:38 PM
It depends on what year your car is and where you live what Lexus recommends
Old 06-06-20, 05:09 PM
mikesrx350
mikesrx350's Avatar
penzoil platinum is best for money,
yes other good oils, Its like front ends and grills everyone has an opinion
Old 06-06-20, 05:39 PM
There are other oils for the same money that are going to be just as good.
Old 06-06-20, 06:37 PM
Received 1,223 Likes on 909 Posts
If you are using any of the real group 4 oils or premium group 3s like Moble1 EP Pennzoil platinum RP etc combined with a similar grade filter you will be fine for 7500 or one year no issues.
I don't personally recommend going over 7500 with any oil if you are interested in keeping wear as close to zero as possible
Old 06-06-20, 07:38 PM
My mechanic actually says 5k miles on this engine, so thats what I stick to.
Old 06-06-20, 09:56 PM
Kuhan
Kuhan's Avatar
If you’re getting free oil changes at the Lexus dealership, then they are putting cheap 5w-20 oil. That’s what they did when I brought the car in for free 4 oil changes. I had to pay $50 extra to get synthetic 0w-20.
Old 06-07-20, 07:30 AM
mikesrx350
mikesrx350's Avatar
best thing to do is listen a Blackstone report of oil analysis not a mechanic..
the ls has 9 quarts or so of oil and some at 9-10 k have reported back the oil is fine with a long way to go with no degradation...
listen to Blackstone or changing every 7500 is safe
Quick Reply: 3k Miles in 8 Months, Should I do Oil Change Soon?
