Air Suspension to Coilovers questions
My air suspension is going out so I have been researching swapping to coilovers. I haven’t found a lot about it but saw a thread where a member was on Megan Racing coilovers and on the max height setting were low enough it probably could not be aligned properly. I have done the air controller on 22’s out of alignment thing for a couple years and went through WAY too many tires like that. I want to make sure that whichever coilovers I get they can be set to a height where alignment is not an issue. Anyone have any suggestions on that?
Does anyone know for sure if the OEM coil springs and shocks/struts will work for the cars that have the air suspension? Is this a direct swap?
Thanks in advance.
Thanks in advance.
These are the ones im getting.
There's a dude here already has them too.
http://shop-fortune-auto.com/collect...ries-coilovers
Thanks! I hadn’t seen those yet. I will look into those. Are you going to go with the default spring rates? Also, are you planning on lowering it enough where you will be out of spec for alignments? I wish there was a cheaper option for adjustable camber.
Thanks, your car looks good! You still at 50-60mm drop? Do you go through tires quickly or is it aligned on spec? How is the toe on it?
Boomin (06-15-20)
VanCityLS4 (06-15-20)
JustChill
Suspension and Brakes
05-24-10 12:40 PM
