Rear Seat Heat controls dont work?
It looks like mission impossible under the seat. Can hardly access anything there. My thoughts was that the plug has dislodged or a dry connection. But can't figure out yet how to take the seat out, or get to the plugs.
2008 LS
Thank you for this! Gives me some hope to fiddle around without removing the seat.
PS. I have another problem - my rain sensor won’t activate the windscreen wipers and the wipers won’t work on the intermittent setting, which is rather annoying in a soft drizzle and traffic.
Update: Replaced the button for the rear seat control and no luckI have also check all Fuses with some connection to seat heating which seems to be alot and still no luckMy only thought is some relay issue but need to keep digging around to see what else could be the problem
I figured out my problem. The rear heat plugs were disconnected. Who ever at Lexus dealer worked on the car forgot to connect the heat element plugs back in. I was changing the rear air suspension and had to remove the rear seats. Once I did I saw it was disconnected. Once I plugged back in everything worked. And once I replaced the air suspension I traded the car in for a new Camry. The LS for me was starting to be a money pit of never ending problems. Hope that helps someone.
swfla (09-30-22)
yes when I was replacing the rear air suspension I had to remove the rear seat and when I did I saw that someone didnt plug it, so I plugged it back in and it worked. And thats when I saw the major coolant leak in the engine and thats when I traded the LS460 for a New Toyota Camry. I miss the LS but the Camry is an amazing car and no more issues like the LS. Good luck.
https://www.clublexus.com/forums/ls-...reclining.html
Last edited by norcalrex; 07-28-24 at 06:13 PM. Reason: edited: did not see that the issue was resolved
