My own interior revitalisation thread. How I知 redoing my plastic and leather
So even if you have the upgraded leather package, the plastic area nearest to the glass and your dash can get sticky apparently. I realised this after I started seeing shiny spots which look like finger marks appearing which do not clean off. The whole dash is shiny, no marks tho and it痴 not very stick but I think it is going to start since the car was exported from the US, I don稚 think I知 covered under ZLZ.
So I am using the stuff I used on my centre console, here I use strong cleaner, i then use adhesion promoter, impregnator which is essentially a layer of vinyl, then use adhesion promoter again and then I use the matte top coat.
here are pics of the plastic near the window glass, before and after and I also steering wheel first round. I知 going to sand it more and redo a bit.
Also check my centre console thread: https://www.clublexus.com/forums/ls-...1-armrest.html
The following 2 users liked this post by jdanielca:
dlbuckls10 (08-17-20),
tomgarv (03-14-22)
Thats why, I am replacing all my interior with the LS 600 full leather interior. It includes the dash and door panels .
aren稚 the top of the door panels same as mine ? If not take a photo you have found so I can see pls. But if yours is in the same condition as mine this seems to be a permanent fix I started off with the drivers door and it has held up over I don稚 know 2-3 months with no deterioration. Although the 600 leather dash is something to behold I知 not going to spend that kind of money on this car lol, I致e already had to spend lots. Plus I値l take some before and after pics of the dash I知 pretty sure for most people it痴 going to be more than enough of a fix.
door panels are easy enough to replace I look forward to photos. I致e seen photos of the leather dash but not door panels, the dash tho is going to be a PITA, but I really wanna see it done I wish you well in your project do post photos
jdanielca (03-09-22)
detailersdomain
Automotive Care & Detailing
15
03-28-09 06:17 AM
