What other headlight mods?
So I need someone who knows more about the 2007 DRL/ high beam set up. I understand that we have a pulsed modulation type thing going on which is the DRL, that issue can be solved later but when you turn your high beams on is it only that putting the bulb at full power? Is there no reflector or something that aims the light higher etc ?
im trying to see if a bi xenon set up is possible using existing projectors.
Tannerkra
10-24-20 06:55 PM
