Transmission issue (stuck in 4th gear)
Hi,
I have a 2007 LS460, and lately its been having a trans issue. It used to be intermittent but it's becoming more frequent. It stays stuck in 4th gear, it doesn't go 1-2-3-4-stuck, it is in 4th from a stop and never shifts. From P to R, it takes a couple seconds before it jerks into R, and that's how i know it will get stuck in 4th. When it shifts into reverse normally it doesn't get stuck. Traction control and VSC light come on as well.
I've read about replacing certain solenoids, Lexus told me I need a new transmission (go figure, $8k). Just curious to see if anyone has had similar issues at all and course of action to fix the issue.
Thanks
Thanks
yes, plus the filter. If its a ZF 8HP45 or 8HP70 the filter is integrated into the pan. There is no way of telling without draining and refilling the fluid (and changing the filter) if the solenoid is bad, or just stuck/clogged up. You can try pulling the codes but that may or may not tell you much. My exact process would be the following:
1. get 2-3 cans of seafoam high-mileage from wal-mart.
2. pull the pan
3. pull the solenoids
4. pull the valve body
5. soak valve body and solenoids in seafoam overnight in a plastic tub/drip pan
6. blow-dry with compressed air
7. reassemble with new filter
8. refill trans using the proper procedure.
9. Disconnect battery for 1 hour (or perform a system reset with a scantool)
10. Drive car for a few days, see what happens.
I highly doubt your transmission is bad, usually when they go into limp mode its a sensor or solenoid. Never seen it happen just from old/dirty fluid unless the trans got too hot. The 8 speeds in these cars are pretty robust so their failure is rather rare. I have only heard of a handful of them since the cars came out.
2. pull the pan
My dealer service advisor mentioned 140k miles cars with non serviced trans that came in with shifting issues.
they backflushed the customers trans and fixed the issue.
trans out of USA is 60k miles service intervals.
2 other local dealers drain and fill. This Berkshire Hathaway owned store does 100 cars a day and backflushes.
as does luxury motor cars in Monrovia, ca which was a dealer mechanic for 20 years and had the luxlink computer override made for the sc430’s.
just saying
just saying
Black_SC (09-18-20)
2. pull the pan
2. pull the pan
just saying
just saying
Black_SC (10-12-20)
Aren’t these transmissions “cheap” used? Want to say I’ve seen them for $1,200, simply because there isn’t a demand for them (the units are that reliable). You could probably get someone to install it for $1,200 or so. All in all in and out for a total of $2,500.
Just saying if you absolutely need one after your attempts at a fix.
Black_SC (10-12-20)
Update:
Did a drain and fill, along with the transmission filter. Did not fix the issue, scan tool was used afterwards and it says "shift solenoid e", "pressure control solenoid "c", and "pressure control solenoid d".
Found this article about the same issue:
https://certifiedtransmission.wordpr...hicle-systems/
miket000 (10-12-20)
Update:
