AC problem in 2012 LS. Driver cold air, passenger warm air.
I get cold air on the driver's side but warm air on the passenger side. I've read all the previous threads on AC problems but none of them touched on temperature difference. Any ideas? Thanks in advance.
Could be the AC amplifier acting up . The part number was updated more than 5 times for some models . or bad servos.
If the ac has a delay and resets the temp to 75 when you start the car it is likely the ac amplifier.
Thanks, guys. That gives me something to go on. The passenger air might be 75 degrees. Hard to say when it's 95 outside. I'm taking the car into my mechanic on Monday for oil change and have asked them to troubleshoot the problem, if it's detectable on the machine.,
I should have specified. If the digital display returns to 75f on startup, not the actual air temperature.
The ac amplifier is behind the glove box. It took me 30 minutes or so. It's not too complicated if your handy.
I purchased one off ebay for $50 or so. There are different part numbers if you have rear ac controls. If you don't have rear ac controls I think any of the part numbers will work, but not positive.
Thanks once more, guys. I am tempted to buy a used one and have my mechanic install it. He is a former Lexus mechanic.
One question: Can he hook the car up to the computer and tell if the problem is the amplifier?
