Side Mirror - LS 460 (2008)
Hi - please let me know if any forum members might have photos or video of a side mirror fix for a loose mirror. I'm able to get the glass mirror off, but at some point (forgot to take pics) I can't get the loose fixture pulled off (vertically). Any help or pointers would be appreciated. I've looked on YouTube and one video got me to the point I am now, but not beyond that.
This is the video that got me part of the way there:
Thanks!
Thanks!
CamelKool (11-11-20)
Great info., but that's not quite what I need. Thank you for posting ... I'll keep it for my next "surgery" in case it helps. Do you have access to a similar drawing but a full exploded view of the mirror and how to take it off/put it on?
Thanks again, much appreciated!
Well you have to pull door panel off and reach up into inner door. Remove the 4 bolts holding in the mirror housing to door. Unplug wiring harness. Once you remove the mirror than 4 screws hold the housing on to mirror motor, etc.
Santa01 (11-09-20)
It looks like I used a 1/4 ratchet, extension and deep well socket. Maybe a wrench too. Multiplex box needs to be unbolted and clear film pulled from door. More pictures here.
https://www.clublexus.com/forums/ls-...l#post10988352
and here https://www.clublexus.com/forums/ls-4th-gen-2007-2017/960290-project-ls600hl-for-cheap-6.html#post10993899
https://www.clublexus.com/forums/ls-4th-gen-2007-2017/960290-project-ls600hl-for-cheap-6.html#post10999864
joedaddy1 (01-29-23)
^^^ my god… how did I not find/see your post earlier during my hours of research…
okay. I thought I had to reach into the gap between the windows and body panel.. I did not know that panel had to come off completely and the module removed to access the clear plastic over..
thank you so much.. I will make another attempt next week.
on another note… after giving up on the mirror, I attempted the puddle lights… of course with my luck, the glass cracked.. I swear reading that it’s almost impossible to crack it but here we are… .. had to buy an used mirror on eBay for ~$50
miket000 (01-29-23)
The crazy thing is.. the mirror was all good and tight after the fix. As I tested the folding function, the mirror has the same 1/2" inch play again.
FYI.. the folding function was not working on the mirror I torx-fixed (even before the fix). I guess the play was due to broken folding motor.
Just doesn't make sense. I don't know how they are related torx / folding / looseness, but I want 2 hours of my life back. haha.
Thanks for the update. I'm in the same boat. Our other LS mirrors won't fold either. There is a 1/2" play on both. I purchased new folding motors but haven't found the time to replace them yet.
Khill
11-09-20 06:59 AM
Nphoops
08-28-18 07:26 AM
