is the factory rotor directional or not?
hi. i purchased a 2011 ls460 awd this augest, the next day i install brand new rotor and pad at a independent shop. but the parts r from dealer
today i put on winter tire, as i take off the rim , i take a look at the rotor, as to my knowledge , it is directional rotor as the vent fin is not straight ( but they r not slotted or drilled, and i notice they have the air hole to help the airflow around the rotor center as it is very similar to 2 piece rotor. but it is still one piece rotor)
and they put it the wrong way
can anyone comfirm this with me, the ls factoty rotor is directional vented or not? thx
if yes, i will go back to ask them install it the right way, but i dont want to insult myself if im wrong
Yes, at least, front rotors are directional.
Yes they are directional
Did you notice when you were watching this video that he took off a set of directional rotors and installed non directional?, you can clearly see the vanes at just past the 3 minute mark and they are pointing forward.
Also he had the air ducts on that car so possibly they come with all awd models or he had a awd sport...I dunno but there was no f sport in 2011.
With three separate threads on this subject, it appears to me there is no clear right or wrong. Doesn't seem to make much difference as no one has experienced warpage or any other symptoms. This thread reminds me of tire and battery threads. Enjoy.
Anfanger (08-05-23)
swfla (08-05-23)
https://www.youtube.com/watch?v=CaSgCEjiF_g
Gerf, what do you suggest? It seems like all of my research indicates they should be to the rear but I called 4 Lexus dealerships to speak to techs and parts department to verify oem specs have the directional rotor with vanes pointing forward. Sadly, it’s so clear from Lexus and even every aftermarket rotor for the awd that they are to be pointed to the front. But I can’t get any rationale for why Lexus wants it that way.
And all suck vs CCBs
And all suck vs CCBs and the LS is blessed with actual brake ducts unlike Audi. Still very shocked by that one...
I would suggest if your car has directional rotors and air ducts and you're not having any braking issues then install them whatever way they have been in the past. This first picture is from that video and you can see the small area the vanes have to draw air from, the second pic is where the air is directed from the air ducts, towards the hub area.
There's so much going on in there I wouldn't worry about it.
