AGM Battery Question
I have a Duracell AGM battery in my 2006 SC 430. The Lexus L00544-MF240-575 Interst G State Battery that I had installed under partial warranty on 3 March 2016 in the LS is starting to show signs that it may be time for a change. Is there any reason why I should not consider installing a Duracell AGM battery in my 2010 LS 460L? The AGM battery in the SC has been great and never ever had a hick-up when lots of folks with SC 430's complain about their lead acid batteries discharging when the car is not driven. Thoughts on installing a AGM battery in the LS
Dennis
Dennis
Anfanger (12-05-20)
They work excellent and all my cars use them since they don't vent hydrogen gas (many negatives to that including rust) and are very good if left sitting often
I would go for it without hesitation. I would only buy an AGM battery as a replacement personally.
Dennis
Dennis
https://www.duracell-automotive.com/...f-construction
jmcraney (12-04-20)
What is the price difference between the two? I use Toyota sold batteries and they always lasted a long time. But I used aftermarket batteries in the past and they worked fine as well. From my personal experience, OEM batteries lasted longer but could be just my luck.
Well since I happen to be looking for a battery, what size or model AGM does the 460 take. I was going to get a battery from Walmart but I don't mind paying more for a quality battery. In the pic above the posts are in the front of the battery where as the 460 posts are in the back.
This is the one I have in the 2006 SC430.
Duracell Ultra Platinum AGM Battery for 2006 Lexus SC430 V8 4.3L 585CCA Car and Truck - SLI48AGM at Batteries Plus Bulbs
Dennis
Dennis
Dennis
Dennis
fwhomeboy
I was thinking of this one.
Duracell Ultra Platinum AGM Battery for 2010 Lexus LS460L V8 4.6L 585CCA Car and Truck - SLI34AGM at Batteries Plus Bulbs.
It is the same AGM Platinum series that is in the SC.
Dennis
Dennis
fwhomeboy (12-05-20)
fwhomeboy
Dennis
Dennis
Read this very old post. The last post, #77 is a good read.
https://www.clublexus.com/forums/ls-...battery-4.html
Biggest that fits, whatever the stock LS430 one is, stock 2017 ram, stock 2014 sequoia, stock WJ, and RX 300. My toy uses a 2005 S-class cell mounted remotely
Brand is Johnson controls from advance auto I believe, they have been switching around makers recently
