Help, out of town
Help, out of town
Needs some advice please.
Out of town no lexus dealer around. Went to drive my 2011 LS sport.
Pulling out of driveway I noticed a bad grinding noise when hit the brake.
We are on the ocean front. And in previous years the rotors can get rust on them overnight. And so occasionally am used to hearing a little grinding and squeal the first use of the day. if a lot of fog/moisture night before.
But this time about 10 times worse and no squeal. And last night not any fog.
Drove a block and when tapped the brakes I heard it again. Bad enough for me to turn around and come back to where we are staying.
Best way to describe. It sounded just like if you ran over a gallon paint can and was dragging along the road.. Or the bottom engine cover came loose and that was dragging. But just when using the brakes. Sounded real bad and did not want to go further. Seemed to be coming from drivers front area.
Anyway turned around and came back and parked it.
Called a friend and he said it sounded like maybe a rock got stuck in the brakes. Took the car back out. Driving slow for 15 minutes in the subdivision. And everything seemed fine.
Not sure if I should do anything. Did find a Toyota dealer a hour away I could go to.
It is a 6 hour trip back home from here and now worried I could get stuck on the road in the middle of nowhere.
Any opinions on if I have a problem? thanks
Also only 45K miles on the car. Passenger air shock was replaced at 35K but not drivers. And did not look like car was leaning. Front brembo brakes replace 10K miles ago with power stop pads. Just to get rid of the squeal.
If the noise went away after driving, it should be OK. Important thing to remember is to press brakes gently until the noise goes away.
RR601 (12-11-20)
RR601 (12-11-20)
RR601 (12-11-20)
Thanks all for the quick responses. I ended up taking the car for one short drive. Then another for 20 minutes at highway speeds. And did not notice any problems.
Did locate a local Goodyear not to far away if I needed them.
So guessing if a actual problem like a bolt or caliper spring if would have happened again. If that sounds right.
All my years of driving never had a sound like that.
08-27-15 06:18 AM
