Jacking up car from rear
Hi guys, I have read the manual. I am changing my brakes this weekend and need to jack up the car. Do I put the jack right under the differential? Not even sure how a differential looks like, but I’m assuming it’s the big silver rectangular looking thing with lines across it.
Is that right? Can anyone confirm that’s the correct place to jack up two wheels at once please? Thanks!
Yes, the rear differential has a spot in the middle for jacks. You also can purchase rubber padding that allow using aftermarket jacks with you car without damage.
thanks a ton!
question. Is it on the actual differential? Like the part that has lines across it? Or is it 5 inches in front of the differential? I’ve been seeing different pics and not sure if it should be on the transfer case or the differential.
Transfer case is next to the transmission, it is way too far from the rear. The rear differential has a spot to support jacks, use only the dedicated area.
P. 640 of the owner's manual
so if I’m standing directly behind the car, and I’m looking at the rear differential (grey square with lines on it), I should put my jack directly under there right? Or should I move it toward the front another 3 inches?
There are two ribs running across the differential. That is where the jack should make contact with the differential.
I updated my previous post with a picture.
Is there a place where I can lift anything other than the Jacking point and diff?
I want to put Jack stand at the rear point, but
Because I only had 2 ton jack, I could not lift it with a differential.
My 2 ton jack blew out oil and broke
I own rubber.
I want to use Jack stand for regular Jack spot, so I'm looking for a way.
Get jack stand pads, it will allow you to use jack stands with jacking points without damaging anything.
differential
https://www.amazon.com/Seven-Sparta-...=34C4J98FVCX13
differential
