Overall Diameter on wheel/tires exceeding 28" on LS460
I recently acquired a set of 4, 21x9 et29 Work Schwert SC2's to put on my '11 LS460 AWD. Messing with offset and tire size calculators, the original size currently installed is a 18x7.5et32(Stock rim) on a 255/50/18 - This grants 28" total diameter with 10" wide.
My question is, to decrease a slight amount, the gap between the top of tire and fender, by going with a 255/40/21 to avoid lowering the car. Will this 1) look ridiculous, 2) have any rubbing issues (It increases the overall diameter to 29") and 3) Fit. According to the calculator I'm using it doesn't seem like it will hit the control arm, but wondering at full turn if it will. (IT does take overall diameter to 29" with 10" width, essentially raising the vehicle half an inch)
Important to note my vehicle does NOT have the oem air suspension & is AWD (Hence why im not running staggered and want to keep the ability to rotate)
I can put a 255/35/21 on and keep everything the same measurement wise as the 18" setup, but the tires are ridiculously expensive, ride is arguably better with a 40 series sidewall, and nothing is available in a UHP all season in that size (Summer or winter only) Michelin Pilot Sport A/S are available in the 255/40/21 however for roughly $1300/set
Much more selection are available in the 255/40/21 (And cheaper)
Appreciate the input!
I recently acquired a set of 4, 21x9 et29 Work Schwert SC2's to put on my '11 LS460. Messing with offset and tire size calculators, the original size currently installed is a 18x7.5et32(Stock rim) on a 255/50/18 - This grants 28" total diameter with 10" wide.
Well, not sure how I missed this the first 10 times perusing through the wheel tire thread (Maybe because its a convoluted mess lol) ...nah honestly I decided to check diameters of 22" wheels since 85%+ of the posts there are ....well, 22"!
This guy went with a 255/35/22 front (Different rear but even larger so np since I'm squared at 21x9 et+29)
His overall diameter is 29% , Width 10%, on stock suspension (Not lowered or air)
255/40/21 is exactly the same dimensions with half an inch more sidewall for added comfort.
https://www.clublexus.com/forums/ls-4th-gen-2007-2017/604361-ls-460-600-wheel-and-tire-information-details-thread-7.html#post9610012
Looks good to me ....ordered the tires!
https://www.clublexus.com/forums/ls-...ml#post9610012
Here's one of 2 or 3 I recall with 24s: https://www.clublexus.com/forums/ls-...-thread-7.html
(post# 105 if you don't land directly on it)
And as far as the fender/wheel gap, I think decreasing it by 1/2' will look good. Most people probably will not notice the overall 1" diameter increase. Do you have any pics of your car's stance the way it sits now?
255/50/18 on stock 18x7.5 et+32 wheel - squared -
& here are the wheels on the guys Lexus I bought them from on stock height no air or lowered suspension . (He was running 245/35/21 all the way around)
Comparison from his setup to 255/40/21 below...
Went with cheaper tires on the order this time around to be sure I like the fitment/ride. 540 bucks shipped....lol
Sweet, nice pick up! Those wheels have long been a favorite of mine, The below is riding on 20s, not sure of tire sizes, but it's in the wheel thread somewhere and I have a feeling you've already seen it. I take it you're on stock, non-air suspension? I think they're going to look great, however, you may get a slight variance in your speedo reading. But such a small price to have nice wheels and a smooth ride you're satisfied with. Looking forward to when you get those bad boys on, gonna change the look of your ride big time!
Yep saw it lol. & no, I dont have air
Im pretty jazzed. Will be getting tires delivered around christmas, have a mobile installer coming out to put them on, will post all the lighting upgrade pics along with the new setup after.
Happy Holidays bud!
Plan is to install them between Christmas and New Years.....that is, if I still have some holiday spirit. All the best to ya brother!
Lol. Hey those arms arent cheap! Just look at your Christmas present visually, at your hands not vibrating on your steering wheel after drinking 20 RedBulls
But here's the reality: new wheels=ooh's & aah's, new control arms=cricket sounds
It's like giving a girl some expensive jewelry vs giving her a mop
Yeah, I created that thread many many years ago and I've gone into it off and on to delete posts that did not follow the intended format as requested throughout the thread. I'll need to clean it up again. As long as folks stick to the format with just posting the template and inputting their specs it would flow much nicer. At least the thread is searchable and there are a ton of examples if folks look through the posts which has grown to many pages now. Hard to herd cats
Edit: I just deleted about 35 posts in the thread, so hopefully it looks a little cleaner now without the replies and random comments.
lwphat66 (12-19-20)
appreciate it Cjitty! May I Suggest having subcategory of stickies within the sticky? 1 For ea. 19,20,21,22+ (Lets be honest there arent a myriad of 24"s on the LS.
Granted its all about people following directions, but could help
The 21" Work Schwert wheel will stick out 3mm more
On stock 18X7.5 et+32offset 255/50/18 Michelin A/S
Overall diameter will increase by 1 inch, 1 inch less sidewall, and same width of 10"
Tinted corner of amber on headlights. Thoughts? I can always pull it off...lol
jdanielca (12-29-20)
