Key Fobs
Key Fobs
Both of my key fobs only work when I'm standing next to the car. If I move away just a couple of feet they do not lock or unlock. I already put new batteries in both, but it makes no difference. I'm thinking it can only be down to the various sensors that are located around the vehicle. Has anyone came across this problem.
Well homeboy, it could be that the batteries are upside down, or maybe I'm thinking my neighbour's Mercedes is my Lexus and pointing the fob at the wrong car 🙄
Even supposing the batteries were upside down 🙃 the doors would not lock or unlock at all.
As you will see from my original post, the fobs work when close up to the car, but not once I move away from the.
Have a look at this thread. There are others like it so just do a search. Good luck!
https://www.clublexus.com/forums/sc4...-distance.html
Did the fobs ever work at a distance and then stop working recently? Has this always been an issue since you had the car? If there is something that was added to the car like Dash Cam or an added GPS or a Bluetooth transmitter or something like that could be obstructing the signal (Antenna) that sits behind the rear view mirror.
jmcraney (12-31-20)
