Help - Missing Battery Hold-Down Parts!
My battery hold-down assembly is missing. All of it, except for the rod in the attached pic and the tray. I found a diagram of parts, but no Toyota part #'s.
Pics of the actual assembly in place would be helpful.
The parts numbers I've found:
74408-50030 - threaded clamp
74408-50030 - main hold down clamp
In the diagram, do I need #'s 6,11, and 12?
I assume the plastic trim cover on the left side of the car attaches to the top of the 74408-50030 hold down clamp? There are 2 holes in the cover with no clips in them now.
Gumart1 (01-18-21)
Gumart1 (01-18-21)
Ahh, much better diagram, thanks! I do not have part #2, that is definitely on my list, along with 4 (and the nut) which I don't have. I was curious about the drain tube. I had assumed it was for an original vented battery but is it for water in the tray? I have to check again if I have the drain..is it attached to the bottom of the tray? Any idea what parts 11 and 12 are for?
I think 11 and 12 are the hold down straps that attach to the pos and neg feed wires. Drain tube is to move water out of tray. When i had to remove my tray to get plugs done the nuts had rusted and i had to break around them to get tray out. I doubt the tube would have helped.
