Overfilled motor oil
Hi all,
last week I did my very first oil change. I lifted the front of the car on jack stands and drained the oil.
I filled it back up with 9.5 quarts (my bad, should’ve only done 9 as there may have been some leftover that didn’t fully drain maybe?) anyway I read the dipstick and it’s past the full mark. It’s about 2 centimeters above the full. I read it while the car was cold as I didn’t drive it around yet. Is that ok? I bought the Kirkland brand full synthetic 0w-20 (2 big jugs of 5 quart each).
do I need to drain? I read another post that said I don’t need to, but want to confirm as I’m super paranoid. I know when I read the dipstick, it’s not an inch overfilled, more like 2-3cm.
one inch is 2.54cm. Do you mean mm? If it’s like 3mm overfilled that’s nothing. If it’s 2-3cm over the mark I’d drain some out
davidcvigi (01-29-21)
lol ok so uhhh if I’m looking at the dipstick ... and measuring the distance between low and full... take that amount and add about 1/4 so uhh maybe 1.5cm over the full line. It’s for sure not an inch haha.
"I read it while the car was cold as I didn’t drive it around yet. Is that ok?"
If you didn't start the car, the oil filter didn't fill up with the new oil yet. Start the car and let it warm up a few minutes, turn it off and after 5 minutes, check it again.
Hi all,
I am sorry but it is a terrible advice. If you get foaming of engine oil due to too much of it, you will regret the decision. And if your engine has some miles on it, some seals might allow some oil through internally and externally. Leaks into combustion chambers will cause spark and catalytic converter problems.
I attached a picture. It’s sooo hard to tell. Is this full? Or over? I put in a total of 9.5 quarts. Just checked haha. Started the car. Let it warm up 10 min. Turned it off. Checked it 5 min after shutting it off.
you see how there’s a small tiny trail of oil above the full?
My personal opinion is fill up to the maximum mark. Some people prefer to go over some don't. I would rather stick to recommend practices than experiment and pay for it later.
just checked again. Literally right now. The car has been off for 25 min now... looks perfect yeah?
Yes, it looks good to me. Recheck tomorrow morning before starting the car.
Thanks for everyone’s help! Love this forum lol. It’s a goldmine for LS460 information lol
fwhomeboy (01-25-21)
It’s fine
