LS600h rear stabilizer bar bearing change
Are there any simple solution to change rear stabilizer bar bearing or do I have to buy a new one and change the whole stabilizer bar with bearing?
I believe, Lexus sells only the stabilizer bar for LS460. I am not sure if the bearing can be removed. I have seen stabilizer bars on Ebay from low mileage donors.
That is not a bad price. I have never replaced the part on LS460/LS600h, so I have no ideas what it is going to take. Do you have description of the rear sway bar replacement?
I was looking at used bars, I do not see a bearing you are looking to replace. I can see 2 rubber bushing but no bearing...
I believe, it is a bushing. Though, it is not serviceable meaning you have have to replace the whole bar. Also, I believe, there are different version w/ and w/o air suspension.
Try parts.lexus.com, use your VIN number. It should provide you with a correct part number.
I took a good look at mine and decided that it’s not worth the effort. I’m flabbergasted at its design and placement. Why, Toyota, why??!
Yes, I understand you. There is same situation like air strut where you cannot change only the tower bearing only you can change whole air strut in whole. It is craziness.
sdls (01-28-21)
I have to lift up my car and see under that I can decide it.
By the way, an active stabilizer bar costs around $9k if you get it from Lexus.
