2014 Clock Spring Replacement Help
Old 01-28-21, 02:30 PM
Zetascry
Zetascry's Avatar
Anyone out there help a brother out, I just want to drive my car 😓
Old 01-28-21, 02:31 PM
Zetascry
Zetascry's Avatar
Originally Posted by Lexus2000
If you turn the key to ON it will trigger the SRS system and will require a code reader to reset.
can tech stream do this reset?
Old 01-28-21, 02:58 PM
Anfanger
Anfanger's Avatar
Techstream should be able to reset any code. But if there is a malfunction, the code will come back.
Old 01-28-21, 03:07 PM
Received 2,926 Likes on 2,464 Posts
Yes. If the battery was disconnected you should be fine. I've never had a problem working on SRS systems with the battery disconnected.
Old 01-28-21, 03:10 PM
fwhomeboy
fwhomeboy's Avatar
I think he disconnected the battery after he had the plugs disconnected, I think.
Old 01-28-21, 03:21 PM
lwphat66
lwphat66's Avatar
Hi guys, I’m replacing clock spring on my 2014 LS460 and I can’t seem to find what this reconnects to.
in the photo it is the connector between my index and middle finger. I have made all connections but I do not see anything for this piece. Could it be an “extra”?
It's been a while, but I definitely don't recall anything out of the ordinary not being reconnected or standing out. The pics between yours and mine show some differences, but the main point is that all plugs coming out from the clock spring should connect to the steering wheel in order for there to be proper rotation and electrical connections to the steering wheel controls. Are the wires you're grasping from within/underneath the steering column? If so, then it's similar to the white plug in my photos. That plug is taped so short to the other wire bundles that it's not really able to connect to anything else. I haven't had any codes, warning lights, or issues.
Same photo, different orientations:
Old 01-28-21, 03:34 PM
Zetascry
Zetascry's Avatar
Exactly from within the steering column/under steering shaft. All connections are made to the clock spring and to the steering wheel. Then this happened.. this red wire came off 🤬idk where this crap goes
Old 01-28-21, 03:54 PM
Anfanger
Anfanger's Avatar
It seems to go somewhere near the steering wheel position regulator.
Old 01-28-21, 03:55 PM
Zetascry
Zetascry's Avatar
not long enough to reach there..
Old 01-28-21, 03:58 PM
Anfanger
Anfanger's Avatar
Are you sure because you have no other single red wire going to the control?
Old 01-28-21, 04:01 PM
Zetascry
Zetascry's Avatar
I thought you were speaking about the white connector. The red wire I still don’t know where it disconnected from.
btw does anyone know the torque for the steering wheel nut?
Old 01-28-21, 04:18 PM
lwphat66
lwphat66's Avatar
37 ft lbf for the steering wheel nut. But not sure about the nut on top of the driver's seat.
Old 01-28-21, 05:20 PM
Zetascry
Zetascry's Avatar
Thank you guys! I have the wheel and everything connected. Drove around locally lol for about 20 min, no issues with any sensors. Just need a wheel alignment..steering wheel sits slightly to the left(maybe didn’t align it properly on steering shaft)
btw that white connector is an “extra”
As for the red wire, I did not find where it connects to
Old 01-28-21, 05:42 PM
toantran99
toantran99's Avatar
You should be fine. Looks like that wire is there for the driver attention monitor. 86471-50010
Zetascry (01-28-21)
Old 01-28-21, 08:12 PM
Zetascry
Zetascry's Avatar
Holy Teeth shattering cold I sat in for an hour just looking everywhere!!
but relieved it isn’t for anything I don’t have at all lmao
Quick Reply: 2014 Clock Spring Replacement Help
