Oops I think I broke my car
#46
Seriously tho', this story is the very first thing that came to mind when I started reading this thread.
sha4000 (02-12-21)
#48
#49
not a huge problems lots of LS here but for what it might be worse off than mine so that’s why we gotta see
#52
Unless Lexus line bores the block to fit the crank most main bearing holes are off a tiny bit.
So most factories use different main bearing shells in each postition to compensate for the holes not being inline
Plus one for an example on a top side and minus 1 on the corresponding bottom side.
as you have experienced an issue with a locally rebuilt engine I would cut my losses and source a good oem motor or another car myself.
Very hard to duplicate Lexus oem assembly in tahara anywhere else,
#53
I keep reading...”the devil you know” to justify keeping this engine and doing these repairs. To me, the devil I’m hearing about in this engine is nothing I want to stay with...blown engine, reved high, previous engine repairs, multiple owners. No thanks. Get another engine.
Most people that own as LS baby them, you have an excellent chance of getting another engine that is in better shape/overall condition than the one you own.
Lower end main bearing replacement is MAJOR SURGERY. Engine removal, tear down, replacement parts, measuring, assembly, torquing...if one little step or component is installed even the slightest bit wrong, it’s game over, rebuild again. And I certainly would replace the piston rings or pistons all together while I’m in there. Low tension rings...if I’m going into that engine at whatever mileage you have to rebuild a bottom end, I’m definitely replacing those pistons while I’m there...because with low tension rings and high mileage, you’re going to start running into oil consumption. Fix that while you’re in there. That’s why I’d find a low mileage motor and bight the bullet and put it in.
#55
If it is just crankshaft bearings, there is no need to remove the engine. You can support the engine with a hoist and remove the lower cross member. It will give you access to the crankshaft pan, removing which will give access to all crankshaft bearings.
#56
#58
I’m not paying 4000 bucks in total to fix a car that can fetch maybe 12 here. The first engine take apart was not my doing, it was this idiot Lexus dealer in this city, I never went back to them after that. This possibly is caused by them too. So let’s see either way if I want to get rid of the car, I’d have to fix it so let’s fix it, gonna cost me maybe 1-1.5k in total right now.
what are low tension rings, I know there are piston rings are there high and low tension rings ?
![](https://cimg6.ibsrv.net/gimg/www.clublexus.com-vbulletin/1600x1200/2350cc10_95a5_43a3_9f68_27fe78e9a86e_357b4c1cfd506a629242f94570de116501543c0b.jpeg)
hfahmy (02-13-21)
#59
The journals need to be measured to explicitly answer that. If the wear is within allowed range, he will get away with just bearings. We will have to wait and see what his mechanic finds.
