No Heat at idle in Cabin
norviewguy, I just had the same problem with my 07 just recently, no heat at idle and intermittent above
turned out my heater "core" needed to be burped, my mechanic said the antifreeze flows from the radiator to the heating unit
and the flow of heat to the interior was blocked, I don't know enough to tell you exactly what he did to fix the heat problem
but it was a minor fix and did not cost too much
How hard was it to reach the inlet and outlet of the heater core?
Not hard at all. Remove the center silver cover and the 2 hoses are on the passenger side firewall. The hoses are most likely on there right even when you remove the clamps so I would spray it down with lubricant and twist them back and forth to loosen them up. I bought some clear hoses I think it was 3/4 inch and one of those transfer pumps from harbor freight that attach to the battery. I filled 1 bucket with water and CLR to pump thru the core and had the exit Hose in another bucket so I could see what was coming out.
Hi:
Had this issue with my 2010. Took it to an independent I have used since I bought the car. It was a gasket at the top of the engine.
This was the total bill. I did have an extended warranty policy ( not Lexus) and that helped, but didn’t pay the total bill because of some BS about not taking in to consideration the additional parts and labor to remove/replace to repair the main issue. Just be aware when you by an extended warranty, they have ways of getting out of paying.
That is a high bill. I am glad, I did it myself. I had to replace many harness connectors too. Some of connectors have release latches broken off.
I do not understand why manifold gasket has a separate charge from the valley plate. You have to remove the manifold to fix the valley plate leak. It seems to me as a double charge.
That is a high bill. I am glad, I did it myself. I had to replace many harness connectors too. Some of connectors have release latches broken off after.
I’m not sure about the charges, quite frankly, unless it is changing the oil, which I can’t do anymore, I really don’t know much about repairing engines, so I have to trust my mechanic. I know if I’d taken it to Lexus, it would have been a whole lot more.
Thanks for your info. I will ask him about it next time I take it in though. Just to satisfy my curiosity.
Hi:
I would not trust that mechanic. He definitely double billed you for the same work. Like he said, they HAVE to remove the intake manifold to seal the valley plate. They might be good mechanics but they are NOT trusted mechanics IMO. Most ppl like you and I'm not being disrespectful are just happy to get the work done for cheaper, especially when the dealer REALLY quotes some outrageous price for the same work. There's no way I would have paid that portion of the bill.
Definitely the radiator. Don’t know where the hole is but I think this explains everything.
Question is what do I do now to pull this thing. 😳
Nevermind found a vid. Anyone that may need it here you go.
