Strustmasters coil spring conversion for 2009 460L
Hi,
Has anyone with 460L changed their suspension?
Suncore doesnt have L model compatible suspension. Strutmaster said RWD one should fit. I am sending them vin# to check compatibility. Its around ~$1200 shipped.
I see few after market air suspension on Ebay but it wont be the same quality as OEM.
Thanks
Thanks
Hi,
Thanks
Thanks
Stay away from strutmaster, shockmaster, suncore and all other no nam,e brands, just buy KYB struts , OEM springs and the necesary hardware to put the strut together
You will need strut mounts, strut insulators for the bottom of the spring , and there may be a few bolts for mounting, im in the process of doing mine very soon
The suspension on the L model is no different then the SWB, its only AWD models that are different
Seems strutmaster are either KYB, monroe or other named brands as per this thread https://www.clublexus.com/forums/mai...-coilover.html
How much are you paying for installation? I got a quote for $250 for each suspension. My front suspension are off by 1degree causing car to steer right, but I will replace all.
Based on suggestion in this thread https://www.clublexus.com/forums/nor...g-install.html I got my struts installed from Exact Motorsports for $960.
Here is the thread where he got each OEM part : https://www.clublexus.com/forums/ls-...nd-shocks.html
I'm paying $700 labour for all 4 shocks
Hoovey689
02-17-21 11:08 AM
devD
GX - 1st Gen (2003-2009)
01-18-17 09:38 AM
mafpolo
03-07-14 11:12 AM
