2007 Ls460 transmission
Hello guys ,
I have seen threads about transmission issues but wanted some feedback on my isssue .
my transmission started blipping in the 3-4 gear change.
I changed the fluid : continued
changed the filter : continued
flush : continued
Through this process the blips became worse and even had problems in 4-5 or 5-6 can’t remember right now and reverse .
when I did my research I come to find out these three gears are on the same clutch pack and share a solenoid .
changed the solenoid : continued
ended up finding a used transmission and it worked fine the first few days and blip returned .
so I suspected the transmission ect.
when I checked it after the car cooling for over an hour it was scorching hot, after I disconnected for 1 minute it cooled .
When completely cold it will sometimes work fine .
Chrome delete, headlight fog light black framed ,reverse lens smoke
Sc300 hiding
I have ordered a used one to test.
questions :
1: anyone ever had this issue ?
2: does this ect need programming ?
3: are they specific to different models I.e. Long / awd / rwd ?
flush : continued
Sc300 hiding
questions :
II know it has pressure to cooler since I flushed it with that line .
also it’s weird that the issue would only be only on one gear set.
same problem on both transmissions .
Try shifting manually and see if it still flares. I’m dealing with an occasional 1-2 shift flare and it won’t do it when I shift manually
Have you tried changing the module instead of whole transmission?
Yes I did change out the etc and the problem continued.
but funny thing I took it to an independent shop suspecting software to be the issue but when they diagnosed they found the software to be fine .
they cleared some codes and recommended I change the balance body or the transmission.
since I left the shop the transmission has been shifting fine .
Hello guys ,
flush : continued
Sc300 hiding
questions :
flush : continued
Sc300 hiding
questions :
