LS460L US version to Europe, HELP
Old 04-24-21, 09:59 AM
bertoni
bertoni's Avatar
Default LS460L US version to Europe, HELP
Hello, in Germany I was able to purchase an American LS460L 2015. The car is wonderful and has only run 11800 miles. I am looking for help in converting the units in the car. Fahrenheit to Celsius, Miles to Kilometers and PSI to Bar. The navigation system is designed for the American market and if anyone here knows how to reprogram it for Europe I would be very grateful. I want the American Japanese to be as European as possible. Thank you all for your support and have a safe trip.
BlazeViper (04-24-21)
Old 04-24-21, 03:54 PM
BlazeViper
BlazeViper's Avatar
I believe techstream can change units, and I have seen a fellow in the UK reflash Japanese market aristo head units into English. There may be someone out there capable of reflashing LS units.
Old 04-26-21, 06:29 AM
bertoni
bertoni's Avatar
Hello, thank you for the message. I have made a request to Techstream. Unfortunately they can't help. I was able to change the mileage counter to KM. Does anyone know how I can change the temperature units from Fahrenheit to Celsius.
All a good trip
Old 04-26-21, 06:40 AM
DaveGS4
Forum Administrator
DaveGS4's Avatar
Received 2,238 Likes on 1,357 Posts
https://www.clublexus.com/forums/ls-...ow-to-set.html
good discussion but no luck
Old 04-26-21, 06:41 AM
Anfanger
Anfanger's Avatar
I am not sure what you meant by "I have made a request to Techstream"...
You need to get access to Techstream software and connect it to your car, in "Customize" section should be "Unit conversion". I believe, it allows changing temperature. I have not tried it myself though.
I read some Toyota/Lexus vehicles do not allow changing units and are hard-coded to region specific units.
Old 04-26-21, 08:51 AM
bertoni
bertoni's Avatar
I have the same problem and live in Germany. The miles can be changed to KM. This works on the vehicle via the display control without other tools. At Techstream I asked if they have a software to change F to C. Unfortunately not. Unfortunately not. I am at a loss here and would like to change the unit from Fahrenheit to KM.
I am grateful for your help.
Have a good trip
Old 04-26-21, 09:43 AM
Anfanger
Anfanger's Avatar
If Techstream does not allow changing units, you might have find used units locally manufactured for your region.
Old 04-26-21, 10:22 AM
bertoni
bertoni's Avatar
Thanks for the tip. Used units for a 2015 model are not to be found here in Europe and not affordable new. The Lexus LS460L is a rarity here. People prefer to drive Mercedes or BMW.
Old 04-26-21, 12:14 PM
Anfanger
Anfanger's Avatar
You might be able to get canadian units as they use SI as well.
Old 04-26-21, 12:23 PM
bertoni
bertoni's Avatar
What units are you thinking of that should be swapped to change the temperature from Fahrenheit to Celsius.
Old 04-26-21, 04:50 PM
BlazeViper
BlazeViper's Avatar
Have a good trip
Techstream is an application/program you can run on your laptop and use it to change settings inside your car.
Old 04-26-21, 05:21 PM
Anfanger
Anfanger's Avatar
Everything that shows imperial units. I could wrong here but I am not sure if you have other choice. Have you tried calling your local Lexus dealer?
Old 04-27-21, 03:50 AM
bertoni
bertoni's Avatar
Thanks for the answer.
I have checked with my local Lexus dealer. The Lexus dealer does not have the ability to go that deep into the system. Unfortunately, he can't help.
I have also checked with Techstream. They also tell me that their software can't do that.
It is crazy. My vehicle is built for America. It speaks English, French and Spanish. The miles can be changed to km.
How do I change the temperature from Fahrenheit to Celsius? It's crazy if it can't do what any little thermometer can do.
Always have a good trip.
Greetings
Old 04-27-21, 04:28 AM
Anfanger
Anfanger's Avatar
I suspect, you will have to change the Temperature Control Module build for non-US market. I believe, the part number is 88650-50N00. Please, do your research as well.
BlazeViper (04-29-21)
Old 04-27-21, 07:57 AM
bertoni
bertoni's Avatar
Thank you for this tip. I will research this with my Lexus dealer.
Quick Reply: LS460L US version to Europe, HELP
