Spark plug conditions
I’d be willing to bet your oil consumption issues are stuck oil control rings, or worn valve guides. And you can easily look inside your intake to see if there’s oil pooling in there: just open your throttle plate and flash a light in there - oil pooling could be a sign of blow by ,(worn rings/stuck rings) will cause this.
R_Rated (06-14-22)
In your case, you will need more just a fresh set of spark plugs.
Ya think? They looked about the same when I changed them 30-40k prior to that. What it needs is oil. Lots of oil. Every time I get gas I top up at least a quart. I have valve cover gaskets and spark plug seals but have not yet installed. She just keeps on humming and loves it when I get on the gas.
oscarneto
10-23-20 10:59 PM
