Spark plug conditions
I was replacing some spark plug tube seals and decided to check my plugs.
Should I replace them? About 78k miles on these original Denso plugs
userix (04-25-21)
I believe, white buildup caused by oil leaking into combustion chambers.
userix (04-27-21)
Can I use any of those head gasket sealer solutions to stop oil into chamber? I know head gasket is going to be costly
Oil getting into combustion champers is usually not related to problems with head gasket. There are different reasons, for instance, valve seals, piston rings, faulty PCV valve. If you have a lot of oil in the intake manifold, it is time to replace the PCV valve.
userix (04-27-21)
is there a quick way to check the manifold without removing it?
Yes, remove the throttle body. You should be able to see inside the intake manifold.
userix (04-28-21)
In terms of oil getting into the spark plug tube itself, is the spark plug tube seal area the only possible entry point for oil? Is the spark plug tube one continuous piece with the rest of the valve cover, or is there another seam at the base of the tube where the spark plug sits that is a possible leak point?
userix (04-28-21)
If oil gets into one or more tubes, it will not able to get into combustion chambers. But oil in spark plug tubes can ruin coils. LS460 is prone to such leaks and it is highly recommended periodically to replace spark plug grommets with valve cover gaskets (can leak too).
You are lighting off oil inside the chambers from ingress past the rings or from the intake from a pressurized crankcase/failed PCV system......or in the worst case BMW style failing valve seals. That's the hardest to address time wise since usually the rings can be cleaned/freed up and it's actually easier to replace them than do all 32 valve seals and guides
userix (04-28-21)
No the tube is pressed into the actual head casting, the seal inside the valve cover that contacts the outside of the tube is one leak point and the grommet on the actual coil is a guard against oil coming into the tube from a leak point such as the high pressure pumps etc.
